almost stalls when i engage the clutch
- Shady469
after the car warms up if im driving and have to slow down to a stop , when i engage the cluth when im about to stop it goes from 1,000 to below 500 for a sec but then rattles a little and pops back up to 750. is this something to worry about? what could i do to fix it?<BR>thanx in advance
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
Re: almost stalls when i engage the clutch
why did you engage the clutch right before you stop?
-93 MR2
#129 E-stock
#129 E-stock
I think he means disingages the clutch, or pushing the clutch down...I have the same problem. I have checked the intake for holes and there are none. So when stopping and pushing the clutch down and break, say on a downhill stop, the car will sumtimes studder and even shut itself off, dunno why...I thought maybe fuelinjectors but i had them cleaned still same problem...Ive posted about it many times, never got a straight reply, so i left it alone
<P>Ryan
92 red rs
performance exhaust
zx2 struts and Eibach springs
turboed + stand alone when the cash is there
- Custommx3
- Site Administrator
Does this happen when you 1st start up the car? does it do it after its warmed up?
kinda happens both, doestn really matter....however it has a tendancy to do it more after a long run at high speeds or hirgh rpms, thats why I checked the intake...<P>Ryan
92 red rs
performance exhaust
- Shady469
yeah when i push in the clutch but mine only does it when its been runnin for like 30 min.
what does the car idle at normally? (warm)
-93 MR2
#129 E-stock
#129 E-stock
- Shady469
like 750 -850
i have the same problem, i think it is a sensor problem of some sort, perhaps the mass airflow, but probably not. thinking something in the O2 area of the intake, the engine is starving at low idle, like there is a pressure loss. i am trying to get to the bottom of this one, i'll post if i figure it out as well.
1992 White MX3 1.6l SOHC
- For Sale - 105,000 miles / 3,000 miles on engine
- Original B6 Bored 2 Over
- Centerforce Dual Friction Clutch
- Short Shifter
- Cross Drilled and Slotted Rotors
- KYB GR-2 Shocks/Struts
- Steel Braided Front Brake Lines
- Reverse indiglo gauges and carbon fiber trim
- Front and Rear Strut Tower Bars
- 17" Sumitomo Tires on Anthracite/Chrome Loco Wheels
- Short Shifter
Try adding some extra grounds to the car. Run them from the block, alternator, maf, etc. to the chassis. Use either 4 or 8 guage wires. This has helped many of the GT/GTX guys with certain driveability issues.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
- Shady469
i doubt its back pressure: i'm runnin 2 1/4" pipe with a high flow cat to a strait through muffler. i was hoping that this would solve this problem when i had stock exhaust but it didnt.
I would try just shifting straight to (n)with no clutch and see if it drops idle,if it does I would start looking for intake problems by spraying non-flamable liquid around intake man.intake flow ports and the throttle shaft area. I am a factory trained Honda mech.with 14 yrs.ex.and that is where we started, If the car has lots of miles I would start looking at the throttle shaft bushings. Chris
I also have experienced this on my car.
