they look drifferent i know i have both models throttle body look different and are wired up different.Originally posted by guyaverage:
Assuming (I dont know for a fact) the SOHC and DOHC use the same throttle body, its on the underside of the throttle body. Remove the large main intake hose, you'll see it.
Idle problems please help!!!!
- Limegreen mx-3
Re: Idle problems please help!!!!
sorry to get off the subject, but whats up Javier this is Curtiss man. DAMN i havent seen you in a while e- mail me at Conceptusa@hotmail.com
mxprecidia
if i do this will i permantly use more gas?Originally posted by hondah8er13:
Look under your hood on the firewall, by the brake booster, there is a plug that says "diagnostic" on it open the cap on it and look at the diagram. you will see one pin that says "ten" and one that says "grd".... warm the motor up to normal temp.. then take a small piece of wire and connect the ten and grd pin together the car will die down a bit..... then turn the screw on top of the intake manifold (may have a cap over it) left raises the idle, right lowers it... be careful the screw is very sensitive... turn it very slow.. also it is normal for your check engine light to come on and even flash.. when you have the idle where you want it then take the wire off and then your done...hope i wrote all that right![]()
also wil lthis make my car faster? and in what ways? thanks
www.illegalCustoms.com
Tri-State Area Car Club
hondah8er13
No not a performance mod, just an idle fix, and you will not use any more gas in fact if you are dealing with a high idle you may use less. this just tells the ecu to remember that this is where the idle needs to be.
Zoom-Zoom
mxprecidia
under the cap i have two grounds and one ten...which ground should i use
white92mx3
I just went out and tried this but it seems to go back to normal after I shut the car off. Should I shut the car off then remove the jumper wire in the diagnostic box? I let the car warm up, put the jumper wire in the diagnostic box from the "ten" to the "gr", adjusted the idle to normal, then removed the jumper (while the car was still running). It seemed to work fine until I shut off the car and restart it. It then idles high again and when I let it sit there for a min it still doesn't seem to go down. On the other hand it does go down to normal (where I set it) from time to time, but it seems to jump back up as soon as I do anything with the car (open the door, turn on headlights, hit brakes, etc...). I was wondering why this is. If anyone can help it would be greatly appreciated.
Life is what you make it.
If you go the link that was posted, there is a post there on how to clean your IAC. That could be your problem.
