Idle problems please help!!!!
Hey guys I have a 1.6 DOHC and my fast idle doesnt work when i first start my car, and when i drive it then come to a stop it idles at around 250 and lower almost stalling!!! What would the problem be??
hondah8er13
Re: Idle problems please help!!!!
have you set the idle from the diagnostic plug?? otherwise it will never be right
Zoom-Zoom
JR
How do you do that?Originally posted by hondah8er13:
hondah8er13
Look under your hood on the firewall, by the brake booster, there is a plug that says "diagnostic" on it open the cap on it and look at the diagram. you will see one pin that says "ten" and one that says "grd".... warm the motor up to normal temp.. then take a small piece of wire and connect the ten and grd pin together the car will die down a bit..... then turn the screw on top of the intake manifold (may have a cap over it) left raises the idle, right lowers it... be careful the screw is very sensitive... turn it very slow.. also it is normal for your check engine light to come on and even flash.. when you have the idle where you want it then take the wire off and then your done...hope i wrote all that right
Zoom-Zoom
JR
Thanks!Originally posted by hondah8er13:
Look under your hood on the firewall, by the brake booster, there is a plug that says "diagnostic" on it open the cap on it and look at the diagram. you will see one pin that says "ten" and one that says "grd".... warm the motor up to normal temp.. then take a small piece of wire and connect the ten and grd pin together the car will die down a bit..... then turn the screw on top of the intake manifold (may have a cap over it) left raises the idle, right lowers it... be careful the screw is very sensitive... turn it very slow.. also it is normal for your check engine light to come on and even flash.. when you have the idle where you want it then take the wire off and then your done...hope i wrote all that right![]()
- guyaverage
"The answer is: More power. I dont care what the question is."
-Tim Allen
-Tim Allen
hondah8er13
yeah go to that link, i could not find it... lol anyway i have done that filter also.. HUGE difference
Zoom-Zoom
Well solved the problem....I had the idle adjuster screw out too far causing to much air into the intake
I don't seem to have the diagram attached to the cap, so if you or anyone else could tell me which pins are the ground and ten ones.Originally posted by hondah8er13:
<img src="http://salicylamid.villarock.com/MX3diag.jpg" alt=" - " />
hondah8er13
Thanks, I'll try the adjustments soon enough!
Spotted
Hey, can anyone tell me where the iac valve for a 94 1.6l is located?
I have had it with this lowsy idle and am going to clean the damn thing nd reset the idle. I just don't know where it is located on my car.
Also, how many tranny/motor mounts do I have to replace to get rid of the vibration inherent to our cars. I am trying to get away as cheaply as possible, I don't have a lot of money.
Thanks
Thanks
- guyaverage
Assuming (I dont know for a fact) the SOHC and DOHC use the same throttle body, its on the underside of the throttle body. Remove the large main intake hose, you'll see it.
-Tim Allen
-Tim Allen
Spotted
Thank you, sir.
Do you know which motor or tranny mount Needs to be replaced to stop the vibration inside the car? Do I have to replace them all, or are there key ones responsible for the shaking?
