Removing amber lens from signal lights
mistahmoogle
Post by mistahmoogle »
No matter what I do, I can't seem to get those stupid amber lens covers off of my signal lights so I can put in the clear ones. The only sticky stuff that I can see is around those notches where the lens pops into those holes in the housing. I've tried heating it up with a blow dryer, but those notches won't budge! Any suggestions? Thanks!
Custommx3
Site Administrator
Re: Removing amber lens from signal lights
Post by Custommx3 »
What SIGNAL lights, u mean the corners or the bumper lights?<P>------------------<BR>Barry Clark<BR><I><B>Moderator</B></I><BR>1995 Mazda Mx-3 RS<BR>Chaste White<BR><A HREF="http://www.barrykclark.com" TARGET=_blank>barrykclark.com</A><BR> barrykclark@hotmail.com
DiGiTaL
Post by DiGiTaL »
Man I feel your pain. I tried everything to get those damn things off. I even took it to a body shop and had them drilled (long story). The only way to get them off is to heat it up a LOT with a blow dryer and use a flathead screwdriver to pry it off. The nothches won't be damaged as long as you are careful not to bend them too far. Just remeber to get them really frickin hot.
DiGiTaL
Post by DiGiTaL »
Oh and one more thing, when you put on the clears, be sure to get the glue hot so they go in easily. Make sure most of the glue is still in the housing or you will have spots around the light that water will get into. Good Luck.
mistahmoogle
It's the one's directly below the headlights, not the ones that are completely on the sides. Thanks for all the advice. I'll be sure to heat that thing up really good!
illapino
Post by illapino »
anyone tried heating them up in the oven, as we do with heating up the halo civic projector housings?
and don't u use silicone to attach the clear lens back on? not glue ??
1992 Mazda Precidia
V6 K8 Engine
Steve_SK
Post by Steve_SK »
Isn't it easier to buy used pair of these from Europe? :wink:
MX-3 V6 1993 | Black | EU-spec | K819
OutlaW
Post by OutlaW »
my car is from Europe and i had the same amber plastic on the lights below the headlights.
I just drilled them, then with a grpling hook broke them off the light, now i have clear lights on the front :D
K8 :: 136.8 bhp---160 nm---108.0 whp---118lbs/torque
ET: 15.567 @ 136 kmh (84 mph)
"Racing a Honda is like being in the special Olympics, you may win, but in the end your still retarded."
Steve_SK
Post by Steve_SK »
Yes, but US models have all blinkers in amber colour, not just inside like our EU models.. I am also going to drill that bulb cover and put Philips SilverVision bulb inside, but what could our US and Canadian friends do? Replace covers or buy blinkers from Europe? :)
illapino
Post by illapino »
for one thing, we are not going to be buying anything from Europe. Trying to find little parts like this are just too rare to have ordered over.. neway, i just got my clear lesnes from corksport, but they don't fit! the notches where the bulb is supposed to 'screw' in are a tad too tight that the bulb's own notches can't get in at all. i called corksport and they'd call the manufacturer and get back to me.
as expected , there's always something . . . . .
1992 Mazda Precidia
V6 K8 Engine
Bochek
Post by Bochek »
why did we bring up a 5 year old post?
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
illapino
Post by illapino »
age is nothing but a number. i only found two topics on this entire forum about the subject, so why make a new one.. the moderators should thank me. i put in search !
1992 Mazda Precidia
V6 K8 Engine
cashmoneyspeed
Post by cashmoneyspeed »
I've always just used a heat gun and a few small pocket screwdrivers to pry between the lense and housing as i'm going along. For really sticky "glue" i just run a razor blade along it. And i always use clear silicone to re-seal the lights, not any sort of glue :wink:
SOLD - 93 GS Custom intake, exhaust, phenolic spacers, port matching, front upper strut bar, 17" wheels, dragon body graphics, black/white interior, sound system, tints, altezza tails & 3rd brake altezza, g-force front
'94 Caprice - rolling fast and low on 20's along with some custom goodies
'86 Regal - Hydraulics, custom wheels, custom paint, shaved, phantom top, leather, power, and lots of chrome
'92 - New import project in the works, should be out in '09
I did the oven trick for mine. They still weren't very easy to come apart
illapino
Post by illapino »
hey, i managed to bake my front signal housings and replaced the amber lenses with clear ones, but noticed that there is an "inactive" bulb insert in the housing: the circular slot where a bulb would normally go in is not cut away ... obviously only people who have taken out their signal housings would not what i'm talking about ... is this a special feature? was a second signal bulb in each housing an option??? ...
it is annoying how the light isn't allowed to spread through the whole signal lens because the housing is actually segmented into two partitions ...
1992 Mazda Precidia
V6 K8 Engine
Return to “Appearance”
