klze with a klde intale and a turbo. will it balance out?
oh-hell
Post by oh-hell »
ok im using my klze in my 92 mx3 gs. I didnt originally buy it for this project but now im using it. My problem is the stock IM will not fit. I know that the best way to fix this problem is to use the mallinea IM but at $250.00 im wanting to use the stock klde intake. Now i know the hype about the klze having bigger intake ports of course allowing for better breathing/performance, BUT if im using a turbo will it work good? I know it will work but how well. Also with the turbo any ideas if i should gut the intake? Anyone have a millenia IM at a resonable price?
[fs] 92 MX3 gs 2.5 klze v6, Intake, Exhaust,drop zone spring{awsome},Turbo, Splitfire plugs, fmu, gauges ,drilled slotted rotors ,motegi rims,tires,Blackout lights, and a nut behind the wheel~~ so far.
MazdaManiacMx3
Post by MazdaManiacMx3 »
It will work , but I believe the intake runners are actually different shapes , (1 is oval 1 is squarish) So you have restriction between the two , You may lose about 10 hp ? Just a guess though
Kris
93 Kandy Tangerine Mx3 GS-DE
05 Saab 9-2x (Wrx power plant)
02 Subaru Impreza OBS
05 Subaru forester Xt - sti mods
04 dodge ram - toy hauler -FOR SALE
& Lots of Toys to haul :D
Spinkx79
Post by Spinkx79 »
You can put some phenolic spacers in between, i believe they port match from square to oval too :wink:
Custommx3
Site Administrator
Post by Custommx3 »
VRIS on a turbo will cause alot of restriction.
Im the PGT we turboed a few years ago, the guy removed all of his VRIS flaps and ported it out.
VRIS is pointless under boost.
BuGS
Post by BuGS »
Custommx3 wrote:VRIS on a turbo will cause alot of restriction.
I thought VRIS was SImilar to Vics, and if so, Vics is what is helping me acheive the same Torque and HP numbers.
Yoda
Post by Yoda »
Which KL-DE manifold are you using? The older vac. operated VRIS or the square port electronic manifold from the solid lifter -DE?
Return to “Forced Induction”
