klze with a klde intale and a turbo. will it balance out?
ok im using my klze in my 92 mx3 gs. I didnt originally buy it for this project but now im using it. My problem is the stock IM will not fit. I know that the best way to fix this problem is to use the mallinea IM but at $250.00 im wanting to use the stock klde intake. Now i know the hype about the klze having bigger intake ports of course allowing for better breathing/performance, BUT if im using a turbo will it work good? I know it will work but how well. Also with the turbo any ideas if i should gut the intake? Anyone have a millenia IM at a resonable price?
[fs] 92 MX3 gs 2.5 klze v6, Intake, Exhaust,drop zone spring{awsome},Turbo, Splitfire plugs, fmu, gauges ,drilled slotted rotors ,motegi rims,tires,Blackout lights, and a nut behind the wheel~~ so far.
MazdaManiacMx3
It will work , but I believe the intake runners are actually different shapes , (1 is oval 1 is squarish) So you have restriction between the two , You may lose about 10 hp ? Just a guess though
Kris
Kris
93 Kandy Tangerine Mx3 GS-DE
02 Subaru Impreza OBS
& Lots of Toys to haul
- BuGS
I thought VRIS was SImilar to Vics, and if so, Vics is what is helping me acheive the same Torque and HP numbers.Custommx3 wrote:VRIS on a turbo will cause alot of restriction.
Im the PGT we turboed a few years ago, the guy removed all of his VRIS flaps and ported it out.
VRIS is pointless under boost.
