KL-ZE ECU
Smokin mx-3
KL-ZE ECU
Anyone know where I can get my ecu reprogrammed or get a kl-ze ecu in canada
pelado
Re: KL-ZE ECU
I believe Sean Matthews at StreetImports can get a J-spec ECU.
David Coleman
Re: KL-ZE ECU
A-spec. [img]shrug.gif"%20border="0[/img]
David Coleman
Re: KL-ZE ECU
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Smokin mx-3:<BR><STRONG>Anyone know where I can get my ecu reprogrammed or get a kl-ze ecu in canada</STRONG><HR></BLOCKQUOTE><P>I would go with a 1.8 reprogrammed ecu from Corksport. The KL-ZE ecu involves a lot of rewiring in our MX-3's.
Do it.......Do it.......<BR>Do it ti'll you're satisfied!
- Custommx3
- Site Administrator
Re: KL-ZE ECU
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by KNOCKOUT:<BR><STRONG><P>I would go with a 1.8 reprogrammed ecu from Corksport. The KL-ZE ecu involves a lot of rewiring in our MX-3's.</STRONG><HR></BLOCKQUOTE><P><BR> Wrong. <B>Maybe</B> a VAF, but no rewiring.
- Custommx3
Re: KL-ZE ECU
I was told by someone who had one in their hand that it was identical.
pelado
Re: KL-ZE ECU
Absolutely no re-wiring is necessary. The myth that re-wiring is needed is gossip, pure and simple.<P>You don't need a JDM VAF. They're the same part number in Japan as they are in the US.<P>You don't need to swap any sensors.<P>The only concern is with the 118 mph (actually in kmph but we use miles) speed limiter. A post by an Aussie contributer said that he defeated this by simply disconnecting the speed feedback to the ECU from the speedometer. Sounds interesting.
white fish
Re: KL-ZE ECU
I'm all most positvie that Tekguy did the KL ZE ECU swap and had alot of hours of rewiring to do<P>but tekguy sold his car and his site seems to be down
Re: KL-ZE ECU
Right, Steve did have a ton of problems with his ZE ECU. His engine was OBD-II ('96 MX-3). His car wouldn't even idle with it in there. OBD-I engines won't have any problems. I wrote a little more about this on the other ZE ECU thread that's up right now.<P> <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by white fish:<BR><STRONG>I'm all most positvie that Tekguy did the KL ZE ECU swap and had alot of hours of rewiring to do<P>but tekguy sold his car and his site seems to be down</STRONG><HR></BLOCKQUOTE>
Hank
'92 MX-3 ZE *SOLD*
'05 RX-8 Touring
--All those who wander are not lost-- JRR Tolkien
'92 MX-3 ZE *SOLD*
'05 RX-8 Touring
ProGTR
Re: KL-ZE ECU
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by white fish:<BR><STRONG>I'm all most positvie that Tekguy did the KL ZE ECU swap and had alot of hours of rewiring to do<P>but tekguy sold his car and his site seems to be down</STRONG><HR></BLOCKQUOTE><P>Steve tried to get it to work, but since all his wiring was already messed up do to his OBD-II to OBD swap it never really had a far chance of being proven to work.<P>I currently know of someone that just had a 323 ZE swap done, which used a mx-3 wiring harness and VAF with a ZE computer.<P>Work's perfect!!<P>Also the ZE computer needs a the Mx-3 VAF in order to work right. A 03 VAF is not the correct unit to use.
