I bought this car for my son and initially it was not running at all, I have replaced disty as it had no spark and fuel pump as it was not working either. Car will start but dies about a minute after starting, I have read through previous posta and have tried pretty well everything I could find that was suggested for this condition. The car will run just fine if I run a jumper from fp to ground in the diagnostic connector but as soon as I pull the jumper the car will die. Vaf checks out, no vauum leaks all grounds have been cleaned, tried 3 differant ecm's as it came with spares and condition stays the same. Tried two differant disty's no change, new coil no change, timing is o.k.
Any Ideas.
Thanks in advance.
