In heavy rain, I have discovered there is some water accumlating on the drivers side front area. This is while the car is parked. My carpet is current out for cleaning, and I don't want to put it back in until i find this.
I will dig into it this weekend, but am looking for any pointers to known leakage issues that may exist. The car sat for years before I bought it.
The two things I want to check first are the A/C ventilation drain in case rain is entering that system, and the drain hose for the skylight. It does not appear to be a door gasket problem.
Thanks,
Jim
Leak on driver's floor?
- umcamara
Re: Leak on driver's floor?
I'm not sure about the Mx-3, but I had an issue in a Caravan where the A/C ventilation line was clogged, and after I cleared it out there were no more pools of water on the driver's side floor under the dash. As you said, this could be your issue.
Just a suggestion if you can't find where it's leaking from, have a friend soak the underbody with a garden hose/pressure washer.
I just noticed that my floor's soaked after washing the underbody with a pressure washer. Time to pull the carpeting out and do some sealing.
Turns out it is the sunroof drain hose on the driver's side pulled out of the hole to the wheel well.
Jim
Jim
