Leak on driver's floor?
jmdearras
Post by jmdearras »
In heavy rain, I have discovered there is some water accumlating on the drivers side front area. This is while the car is parked. My carpet is current out for cleaning, and I don't want to put it back in until i find this.
I will dig into it this weekend, but am looking for any pointers to known leakage issues that may exist. The car sat for years before I bought it.
The two things I want to check first are the A/C ventilation drain in case rain is entering that system, and the drain hose for the skylight. It does not appear to be a door gasket problem.
Thanks,
Jim
umcamara
Re: Leak on driver's floor?
Post by umcamara »
I'm not sure about the Mx-3, but I had an issue in a Caravan where the A/C ventilation line was clogged, and after I cleared it out there were no more pools of water on the driver's side floor under the dash. As you said, this could be your issue.
Just a suggestion if you can't find where it's leaking from, have a friend soak the underbody with a garden hose/pressure washer.
I just noticed that my floor's soaked after washing the underbody with a pressure washer. Time to pull the carpeting out and do some sealing.
'96 Silver Stone Metallic MTX RS
'98 BMW 328is M-Tech
Feedback Thread
jmdearras
Post by jmdearras »
Turns out it is the sunroof drain hose on the driver's side pulled out of the hole to the wheel well.
Jim
