Tough Transmission
asimpson719
Tough Transmission
Post by asimpson719 »
for a while ive noticed that right when i start my car and im driving before its fully warmed up i get a kinda rough shift into second but once its warm then it shifts smoothly.
just the other day i noticed that it was extremly hard to shift and i ended up having to skip gears cause it would not go into a certian gear while i was getting on the freeway.
but if i double clutch it then it shifts smooth and no problems any idea what could be causing this?
could it be low / bad fluid?
or the synchro?
or just the tranny going bad?
_-Night-Shade-_
Re: Tough Transmission
Post by _-Night-Shade-_ »
If double clutching helps then synchro is a possibility. It will always be a little rougher when cold due to the tranny oil being thicker, maybe flush and add some synthetic?
asimpson719
can you replace the synchro or should i just get a new tranny?
and if it is the synchro thats bad will the tranny still last as long as i keep double clutching?
_-Night-Shade-_
I'm not an expert on this but some of the veterans will answer this soon I'm sure :P
Ryan
Post by Ryan »
I'd vote run the tranny untill it nearly explodes, and then pick up a junker unit for $75. Drop out drop in. Easy.
Tranny rebuild = scary and expensive
Return to “Transmissions”
