m62 pulley
klmx08
m62 pulley
Post by klmx08 »
i was just given a m62 supercharger off a clk 230 my only problem is it dosent have the pulley and i cant seem to find one anywere. does anyone no were i can get one or if it is possible to get one machiened?and last but not lest can they be mounted in the a/c location like the probe and mx6 guys do it? any help would be good
JWMX3
Re: m62 pulley
Post by JWMX3 »
the CLK pulley will only make you 2.5 psi of boost. some guys get an overdrive crankshaft pulley to increase the boost, I think theres a guy on probetalk who makes them. Or else you would probably have to get a custom made smaller supercharger pulley. the bracket to mount the S/C will have to be custom made and your oil filter needs to be relocated.
thats only a few points I just made.... you probably need to get on probetalk.com and do some research on the ac mount supercharger. good luck ! :wink:
klmx08
Re: m62 pulley
Post by klmx08 »
ok thanks man! with an overdrive pulley how much boost will that make?
WhiteFinish
Re: m62 pulley
Post by WhiteFinish »
Depends on the pully
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
Re: m62 pulley
M62 is the same my X has. It's stock pulley makes 6psi (8 with the boost bypass mod). A 2.4" pulley will do 10psi, 2.3" pulley will do 12psi (15 on mod).
solo_ryder
Re: m62 pulley
Post by solo_ryder »
^ Correct
Except that the Stock mx3 drive pulley doesnt help and causes super low boost on our cars, and mix that in with IC piping you will make like 1lb of boost. If you get a 2.4-2.5" aluminum pulley made for the M62 (with the key insert) then you should be able to make 7.5-9psi of boost with 2 1/4 IC pipes and a small intercooler.
I talked to Aldorin on PT about making a overdrive pulley. PM him and he may be able to recreate one for you. That is a easier option then having one made for the M62 as they are not the easiest thing to find. You will also loos clutch capability if you get a new pulley for the m62.
Re: m62 pulley
solo_ryder wrote:^ Correct
That's true that the speed of the supercharger also depends on the size of the pulley on the crank turning it.
Will these pulleys not work? 2.64 to 2.3:
https://www.4x4parts.com/catalog/index. ... th=367_385" onclick="window.open(this.href);return false;
What do you mean clutch capability? I take it some M62's have a clutch option to engage/disengage the charger?
solo_ryder
Re: m62 pulley
Sweet yea those might work as they are press on pulleys. They need to be key notched though.. I am sure you can get a shop to do that, I am not sure if the snouted xterra m62 is different from the amg mercedes version in terms of the pulley and how it is installed
klmx08
Re: m62 pulley
Post by klmx08 »
hey thanks everyone i will try the website provided i cant imagine it cant be done! but what size would i want for 5 lbs boost with intercooler and stock crank pulley?
solo_ryder
Re: m62 pulley
What motor are you running? Why 5psi? Are you gonna run a FMU/FPR combo?
You would need to post up on PT to get eact pulley sizes for that much boost. Take into account 1-2 PSI loss over the IC pipes and Intercooler.
klmx08
Re: m62 pulley
Post by klmx08 »
i have a klde probe gt engine and yes i want to run a fmu/255 fuel pump combo
Return to “Forced Induction”
