bp internals
4gotn
bp internals
Post by 4gotn »
ok so i ordered a bp finally and im probably going to rebuild it from the pan up
Ive been looking around protege and miata forums and wiesco pistons/rods seem to be the most popular but ouch
does anyone know of any forged internals that are worthwhile and easy on the pocket?
btw im shooting for about 12lbs of boost (t3/t4) but i want the engine to be able to handle over 25lbs in case i decide to crank it up
1994 MX-3 1.6L B6DE 16v DOHC - rear disc swap, nix power steering/ac, Corksport f&r strut tower bars, Pedders urethane control arm bushings, urethane motor mounts, steel braided brake lines, painted dash, protege tranny
90 Miata w/ b6, Konig Lightspeed rims, Cams (boost to come soon)
74 Porsche 914 w/ 1.8L - restoration prooject
Mi|<E
Re: bp internals
Post by Mi|<E »
Have a look at my worklog and check out :
http://www.belfabracing.com/newsdesk_in ... d859934d69
jcallaway86
Re: bp internals
Post by jcallaway86 »
This might help. The stock BP should be good to 250hp daily driven from what I understand.
Straight from Wiki:
The 1.8 L (1839 cc) BP is a dual-overhead variant of the B8. It was first found in the 1989 Mazda Familia and American-market 1990 Mazda Protege LX. This engine was dubbed BP-ZE and featured a forged crankshaft, piston oil squirters, an aluminum baffled oil pan, and Variable Inertia Charging System (VICS).
I would suggest that if you are going to turbo, remove the VICS. Mazda did on the BPT, and they did it for a reason.
