which year/model millenia alternator fits a ze?
Question is, which year and model Millenia alternator fits my ze? Correct me if I'm wrong but the Millenia alternators are 110 amp? Worth the trouble for the extra 20 amps?
94 mx3 rs
92 mx3 gs curved neck klze SOLD
- Custommx3
- Site Administrator
Re: which year/model millenia alternator fits a ze?
Requires a millenia harness and wiring in an extra power wire.
so it doesn't just bolt on?Custommx3 wrote:Requires a millenia harness and wiring in an extra power wire.
94 mx3 rs
It does just bolt on if you have the correct bracket and connector (most easily found at a junkyard)... but there is an extra wire you need to wire up (as barry has already mentioned)
there is a great writeup from Tunes67 about this... tells you everything you need to do...
I'm not sure what year millenia works but all that contain the 2.5L v6 should work.
