Posted it on Craigslist: http://seattle.craigslist.org/tac/car/525396264.html" onclick="window.open(this.href);return false;
As the post says, everything in the engine bay is straight and mostly new. All synthetic since I bought it in 2003 including flushing the power steering and brake fluid with synthetic when I first bought it.
It needs to be painted bad. It's already been wet sanded and wouldn't require much more prep before taking paint to it. A couple simple little things too:
-rear driver's turn signal and the driver's seatbelt are unresponsive - happened when car stereo 'pro' extended the rear wire bundle to move the fuse box. All that should need to be done is take his wiring apart and solder the connections that he crimped instead.
-trunk is gutted. If you want it finished you'll need to get a set of trim panels from the junkyard.
-one rear trim panel has a crack in it
Other that that, she's pretty squared away. Even have the OEM floor mats that I took out when I bought the car to preserve them. Just threw them in today to get ready for sale.
