Just finished it up, works great, drove after doing it for a 30min ride runs nice and smooth.
Pics:
As you can see i tried to drill off center to tap into the wire, like all the HOW TO's say to do, doing it this way is the incorrect way and a pain, Pat and I decided to drill and tap the center, allowing the screw to pass through the center metal gromit piece, This is a better way than to drill and tap into a wire, not knowing how well the connection is.
I did an easier to read diagram for the mx-3 (this is basically idiot proof)
Heh.. now all you need is a Millenia alternator and you'll have the consistant power to feed it Been waiting for you to finish this mod so I can talk you into doing a dyno run to compare to the run you did last year Cheers
Tunes67
let me get a couple of 100 on it to make sure its gonna work just fine and i'll go to the dyno to see the difference, i believe the power will be in the same range, but i think the curve will be alot more smoother
Here one I made for just the HEI mod after I did it last year
Of course it doesn't have some info that you have since I didn't do the HEI mod, so i dont want to incoporate anything I didn't verify and do myself, but on yours, the blue/orange, I could of sworn it was Orange only, maybe Orange/Blue, as in Orange with a blue stripe? As well, what's the significance of the "750" you have marked there?
1992 Mazda Mx-3 GSR - 2.5L KLZE : Award Winning Show Car & Race Car ['02-'09] (Retired) 2004 Mazda RX-8 GT - Renesis Wankel : LS3 Coils, BHR Mid-Pipe + Falken RT-615K 245/40r18 2011 Mazda Mazda2 GS - 1.5L Manual : Yozora Edition (1 of 500) 2003 Nissan Xterra SE - 4x4 Supercharged : 2" Body Lift, 4" Suspension Lift & 33" MTR Kevlar 2001 Nissan Frontier SE - The Frontrailer : Expedition/Off-Road Trailer Project
Making sure that clean filtered air is pulled in, the setup worked well on my kf motor when i did it sept i used 1 breather filter for both heads, this time i just decided to do 1 per head, works well though i cant say it doesn anything really, doesnt hurt power or the motor any so....
Your right its Solid orange, with blue stripes, I just was looking over all the other diagrams they said blue/orange, but yes your right it should be orange/blue for the discription. I just changed it.
Mnemonic wrote:Making sure that clean filtered air is pulled in, the setup worked well on my kf motor when i did it sept i used 1 breather filter for both heads, this time i just decided to do 1 per head, works well though i cant say it doesn anything really, doesnt hurt power or the motor any so....
its a vent it doesn't necesarly pull air in. more air will go out actually. Just be lucky you don't get cought. thats a hefty fine if you get caught.
eh i'm gonna get in more trouble for having nothing for the egr system hooked up, not worried about it though my cars registered in a no emission testing area......
Mnemonic wrote:eh i'm gonna get in more trouble for having nothing for the egr system hooked up, not worried about it though my cars registered in a no emission testing area......
not really. thsoe breather filters are easy to spot. egr isn't. If you lied were i am They pull ovr moded cars and inspect them and would nail you for that. May not be like that were you are but its still illegal.
If my coil dies.. this is DEFF my next mod. you make it loook so easy.
-hec
ok probably a stupid question but.... what are the advantages of this?
There are a couple of obvious benefits..
1) Far less expensive than a new distributor.
2) Far more reliable than the Mitsushitsi produced distributor (OEM disty)
3) Potentially better spark equalling greater ignition, which of course results in more power and better fuel economy.
4) Its freaking cool as heck
5) Its sexy and will improve your overall attractiveness to the ladies.
6) Do I really need to go on?
Tunes67
