Pulling the pedals?
projectmx
Pulling the pedals?
Hey i need to pull the pedals out of my car.... how do you do it? any help would be much appreciated
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
- Tunes67
Well you could always do what I did when I converted my GS from an ATX to an MTX.. It wasnt pretty.. but.. in the end.. it worked out rather well for me.. I bribed a friend with a steak dinner at a local steakhouse so I wouldnt have to lay upside down in the car for 2 hours. If the steak dinner hadnt worked.. you might have to hire a stripper.. I was prepared to do so for him.. This may seem extreme.. but I REALLY didnt want to have to do that job after I took one look under my dash LOL
Tunes67
Tunes67
- atlantamx3
- kiwi_MX3
- Location: Backpacking in Canada in vancouver 13march onwards
to remove the complete pedal box assy.
Remove master cylinder / brake booster assy
Remove master cylinder clutch
there are six nuts on the firewall you have to undo
remove drivers seat. ( and assume the position with a socketset in reach )
under the dash you have to unplug
the brake pedal light switch
the clutch switch? ( yea i know ?? but there was one on mine )
unbolt the lower steering colum support ( two bolts )
unbolt the pedal assy upper ( two nuts )
volia should be able to move the assy forward then out.
Should be noted that RX7 S1-3 323, RX3, 323 and MX3 pedal boxs are the
same in design.
same in design.
projectmx
what about escorts and proteges?
and is rx-7 s1-3 gen 1 through gen 3?
is 87 323 the correct year?
ProjectMx
Cardomain
Cardomain
- kiwi_MX3
after going and looking at my collection of partsprojectmx wrote:what about escorts and proteges?
All FWD cars ie 323/familia/protege/mx3 on BG chassis share the same
pedal boxes
The ford equivalt of the BG chassis will fit as im using a ford steering
rack
RX7 S1-3 ( or Gen 1-3 ) fit into RX3
RWD 323's fit into RX3
projectmx
there is a RWD 323?!!!
cool.. i'll let my friend know he can nab one either the 323 one or one of the escort ones
ProjectMx
Cardomain
Cardomain
-Jim
