car will turn over but wont start just happened. with key in the on position cant here the fuel pump under the back seat.  Is it pouched or is there a fuse that might have gone bad and where would I find it...
or would it be something else
Car 96 mx-3 v6 gs  5 speed
stock motor
							Where or is there a Fuse for Fuel pump
STeve
1996 Black MX-3 GS
North Bay, ON Canada
If your in North Bay lets hang out and go for beers
						1996 Black MX-3 GS
- jschrauwen
Re: Where or is there a Fuse for Fuel pump
Relay at passenger side of center consol kick panel - right beside ECU. Also fuel injector relay(s) under the hood.ven wrote:car will turn over but wont start just happened. with key in the on position cant here the fuel pump under the back seat. Is it pouched or is there a fuse that might have gone bad and where would I find it...
stock motor
Have you not sought the information from the online shop manual? Start with page F2-105 and then proceed onward.
					Last edited by jschrauwen on October 30th, 2006, 3:31 pm, edited 2 times in total.
- jschrauwen
Yes, like mentioned previously, it's covered step by step in the online shop manual.ven wrote:drivers side? is there a test to see if my pump is good or bad even if the hum isnt there
