K8 Temperature
K8 Temperature
Temperature gauge shows me temp of my engine somewhere in 3/4 of the scale. I am used to have temperature a little below 1/2 of the scale on my other Mazda's. Is it normal or is there something wrong with my cooling system?
well yes you are correct most mazda coolant gauges read 1/2 mark is normal temp.
ither you engine is running alittle hot. or your gauge is in accurate.
if you have an infered temp gun than you can test your gauge.
im pretty shure 1/2 mark is around 200f.
if you dont than replace the temp sender if your gauge reards normal than your done if your gauge reads the same than you must have a efecincey problem with you cooling system.
JUDGE ME ALL YOU WANT
93 gs, klde swap, kl trans, strait 2.5'' ehaust, euro front bumper, cold air intake, hei ign ,50 shot &
9.60s n the 8th mile so far 8.50s sprayn now
150 shot
150 shot
It is 1993 MX-3, I have another Mazda from 1993 - 626, I had the same problem, I exchanged old thermostat, get new Antifreeze in and the temperature is the same. I can notice some coolant leaking of the radiator, is it possible due to lower pressure in cooling circuit (fault radiator) the temperature is higher? Maybe water pump damage?
According to Mazda Owner's Manual, the range from the first white line to the second white line is normal operating temperature of the engine, but I am used to read 1/2 of the scale. I really don't know what to do..
Seems like I bought another wreck..
- Custom_V6_Limited_SE
If you have already replaced the temp censors, I would tend to think you need a new water pump. The radiator shouldn't affect it unless it is a big leak. If you are able to check the engine temp with something else, I would also recommend that before messing with the water pump. If the radiator just has a small leak, it is really going to be more of an annoyance (Unless you let it run dry) than a major problem. I had a leaky radiator on one of my MX-3s and I just decided to replace it.
'93 MX-3 GS SE:My Mods
an over heating car can be caused from air in the system, faulty tstat, faulty water pump, old sludged coolant, blown hg, clogged radiator. if its not really over heating then the temp sensor, or gauge may be messed up.
if your water pump failed normally it would be pissing water from the water pump seals. if you notice a leak,that leak could be letting air into your cooling system which doesnt help coolant it circulate.
u can tell if your car is really overheating by idling it with the radiator cap off and
1 see if the coolant boils over after a while
2 feel the hot and cold hoses to see if the coolant is circulating.
point is mx3 over heating may or may not be the same reason your 626 over heat. dont assume that what is wrong with your 626 is the same issue as your mx3 cuz several things can cause the same issue. the gauge or temp sensor is not a common problem for either and you were probably just unlucky with your 626.
there are 3 temp sensors all located by the radiator cap on the pass middle of the engine. the small 1 wire sensor with black connector. is for the temp gauge
150 shot
150 shot
My gauge needle goes a little down (1 mm) when driving outside my town, I have a leak from radiator, but when I pressured the cooling system (1 bar), there was no leak.. It is strange.. I am going to buy a new radiator tomorrow and I will also exchange thermostat. I will see. And, of course, I will buy a new coolant. I am also thinking about cleaning the cooling circuit with special cleaner (BG Care, I think).. Hope it will help to lower the temperature a little.
yes dude thats a pic of a temp gauge above the middle mark. read above posts. all the info you need to diagnos problem there for you. read posts.
150 shot
150 shot
