My girlfriend has a 93 V6
Last winter when it started getting cold it wouldn't start.
I figured out if I tapped on the dash it would start fine. First I thought it was a problem with the clutch start sensor so I disconected it.
That didn't help so my next thought is a starter or main ignition relay.
The car won't start at all now so I think it's time to fix it.
We had this same problem with her CRX and the honda guys told us exactly what was bad and where to find it.
I am hoping this is a simalar common problem you guys may be able to help me with.
Car won't start. Help me diagnose
Last edited by yoshimitsuspeed on October 5th, 2006, 5:15 pm, edited 1 time in total.
- mr1in6billion
Sorry about the break. I fixed it. I must have picked up my laptop by the enter key or something.
Custommx3
I guess I missed the detail that nothing happens when you turn the key. Power is not getting to the starter.
I am pretty sure it's inside because like I said a tap on the dash got it cranking for months.
mr1in6billion
At least with our car disconecting the clutch sensor just made it so we didn't have to push the clutch in to start it. The only negative side effect was driving with cruise on hitting the clutch to disengage the cruise and having the motor over rev
Custommx3
mr1in6billion
What about the battery, does it have lights or just wont turn over?
93 gsr,KLZE with millenia intake, phenolic spacers, HKS intake, limitedslip-auto to manual conversion,centerforce clutch, 75hp NOS wet kit, MSD with blaster coil, white gauges, pacesetter shortshifter, Tenzo seats, lowered 2 inches, Konig Traffik white rims, cat back exhaust
check all the wires to make sure they're plugged in. But check for codes first. put a wire in the diagnostic box under the hood. Put one end in GND & the other end in TEN. then go in the car turn the key but dont start it. The check engine light will blink a certain number of times to tell you whats wrong with the car. write down the number of blinks. a long blink is ten by the way. so if it flashes 5 times its code 5. Look it up on the online shop manual on the mx-3.com page. I don't remember the exact page the codes are on. Anyways g/l
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
4 mx3 GS SOLD-
