Fuel Pump?? Electrical Problem?? Help Please
- matrice
Ok, Well, I was hookin up 2 amps in my car yesterday, and got one to work , and hooked up the second, and the car shut off, and wouldnt start again, stereo wont turn on, turned the key to acc, and the heat gauge shoots up to the top for some reason, the brake light and belts lights are very dim on the dash, it will turn over but wont start, there is a tickin comin from the fuel pump relay fuse?? and i cant hear the fuel pump kick it when i turn the key, i checked all the fuses and they are good, any help would be appreciated, thanks
- mx3autozam
check all fuses first....
94 Mx-3 Precidia
- matrice
changed the relay fuse from a protege one, started after that, but then i tryed my headlights and it shut off,,, damn, then i took the key out of the ignition, hit the break pedal without the clutch and the heat gauge went up, check engine, oil, and charge lights came on, really weird for not having the key in, may be the altonater? What can i get for a larger altonater?? like a larger producer of power??
No i dont have an extra ecu, how do i check for codes?? Ill try to get a voltmeter tomorrow, everywheres is closed now.
