Wiring Problem
bigsy
Wiring Problem
Post by bigsy »
Hey
Im in the middle of doing my klze swap and have so far found a wire i have no idea what to do with, the one from my k8 comes out between the two valve covers and right from under the intake manifold and the sensor has two wires. The one from my KLZE has only one wire and the plugs are different. Any advice on this mystery sensor and any advice on any other problems i might run into?
Thanks
Ben
solo_ryder
Post by solo_ryder »
Thats your knock sensor, but I am not sure why it would have 2 wires, it may be the year of the motor, mine only had one and it plugged right in
XxantwawnxX
Post by XxantwawnxX »
Can ya snap a pic?
hgallegos915
Post by hgallegos915 »
Mine has 2 wires... one is ground another is power to knock sensor. red and black... I think the obdII had one? im a 92 gs.
-hec
bigsy
Post by bigsy »
I would love to post a pic but i am computer illiterate and dont know how to do so on this forum, sorry.
