Hey
Im in the middle of doing my klze swap and have so far found a wire i have no idea what to do with, the one from my k8 comes out between the two valve covers and right from under the intake manifold and the sensor has two wires. The one from my KLZE has only one wire and the plugs are different. Any advice on this mystery sensor and any advice on any other problems i might run into?
Thanks
Ben
Wiring Problem
- solo_ryder
- XxantwawnxX
Can ya snap a pic?
Mine has 2 wires... one is ground another is power to knock sensor. red and black... I think the obdII had one? im a 92 gs.
-hec
