Hold Light Flashing
Hold Light Flashing
Hey guys i was just woundering what are some ways to fix this problem with the hold light flashing?
- Aston Wards
- neutral
Re: Hold Light Flashing
Echos to what Aston Wards said. That flashing light is a warning to pay attention to it and bad news could possibly follow. Go straight to the online manual. Pull the codes and go from there. Also check your tranny fluid level and fluid condition now. I can say from experience on my MX-6 that a significant number of Mazda/Ford auto trannies do not hold up well over time because they run too hot. Do you have an auxilliary trans fluid cooler installed?Beebo wrote:Hey guys i was just woundering what are some ways to fix this problem with the hold light flashing?
Maybe there is time to avoid rebuilding that atx - a task you either pay a pro to do, or if bravely (foolishly?) attempted as a DIY project, ya suffer a slow painful brain death in the fifth circle of Hell. Anyway, asap, pull the codes, check the online manual troubleshooting code guide, and post back if ya get stuck or need moral support.
-Jim-
papadeez15
