Guage Cluster?
Guage Cluster?
I want to mod my guage faces But I'm not to sure how the speedo,fuel ect. needles come off??? Can someone help me out?
- Hoodzy
its in the faq and just search
1995 Creek Mica Blue GS
- PATDIESEL
Most aftermarket face require the needels to come off, but if you cut the small back end off then you can slip the new faces over the needles and ontop of stock ones.
People do this because resetting the needles is terribly hard and the needles will beak easily leaving you with a need for a new cluster.
To answer your question tough, they just pull straight off. Use a pair of needle nose pliers or something to grab the needle and pull gently making sure you don't slip off the needle. It takes a bit of force to get them off.
be carefull buddy you don't want your tach ending up like mine it spins the other way counterclock wise you just have to pull the neddles stright towards you and just remember were they were pointing when they came off worse case senerio you'll have to take a drive down by niagara college (the one off mountain road) and adjust you speedo by what the radar says your going thats why i did if you need anyhelp just give me a call and i can give you a hand.
also do you still have that power steering pump lying around if so i may just have to pick that up off of you sometime after friday.
but i have good news i got transfered to the st. catherines best buy and i'm in the install bay so if you want swing by.
Reaper
Greg
(905)351-3747 cell ##
Reaper
Greg
- monty73741
goto mazdamaniac.com he has a how to
Jason Danaher
Please Help Support MX-3.com
all you do is set fuel needle at a 10 o lock position and walla it sldes in!
-hec
