KLZE: PGT Vs. MX-3
				Amma351
KLZE: PGT Vs. MX-3
I was just wondering, If a probe and a mx-3 both had a KLZE swap properly done, which one would be faster?
Either from a theoretical or experienced point of view?
Cheers
Sasa
Cheers
Sasa
Same power, same gear ratio, they would both be just as fast and max out at ~240km/h, but the Mx-3 would accelerate faster because it's lighter.
				lakersfan1
				LooseChangeRacing
how would the tire size affect top speed....gear ratio's affect top speed....
							http://www.cardomain.com/ride/2385931/4
Car Name - Elsie (LC)
Car Type - 92 Black RS Stock 190k
Car Name - (yet to be decided)
Car Type - 93 (soon Black) GS KLZE 130k
Because your have the main gear ratio (1-5), then the final drive, and the diameter of the Rim/tire is the final gearing.LooseChangeRacing wrote:how would the tire size affect top speed....gear ratio's affect top speed....
The probe and MX-3 use the same trannies, but because of the tire size the top speed would differ by about ~10-15 mph. The Mx-3 tops out at ~140 MPH, i have done it many times.
My friend has a ZE in his probe, and i have one in my MX-3, and we pretty much have the same bolt-ons, and there is no comparison. The Mx-3 is alot lighter...plus mine weighed in at ~2240 lbs, and his was ~2760 lbs
						Here's how it works:
Your engine turns at a certain speed, for this example, we'll say it is turning at 7,000 rpm.
The Probe GT and the MX-3 GS both have a 4.39:1 ring & pinion, and a 0.80:1 fifth gear ratio. You would then multiply both numbers together, and then divide your engine RPM by the result to get how many rpm your wheels are turning:
The rolling circumference in millimetres (mm) can be calculated like this:
To put this in more easily comprehended numbers:
- Engine RPM / (Ring & Pinion x Gear Ratio) = Wheel RPM
 7000 / (4.39 x 0.80) = Wheel RPM
 7000 / 3.512 = 1993 RPM at the wheels (approx.)
- ((Tread Width * Aspect Ratio * 2 sidewalls / 100) + (Wheel Diameter in inches * 25.4 mm per inch)) * Pi = Rolling Circumference in mm
 For the MX-3 GS's stock 205/55-15 package:
 (205 * 55 * 2 / 100) + (15 * 25.4) * Pi
 (225.5 + 381) * Pi
 606.5 * Pi = 1905.38 mm (approx.)
 For the Probe GT's stock 225/50-16 package:
 (225 * 50 * 2 / 100) + (16 * 25.4) * Pi
 (225 + 406.4) * Pi
 631.4 * Pi = 1983.60 mm (approx.)
- Wheel RPM x 60 = Wheel Revolutions Per Hour
 1 kilometre (km) = 1,000,000 millimetres (mm)
 So...
 1993 x 60 = 119,580 Wheel Revolutions Per Hour
 119,580 x 1905.38 / 1,000,000 = 227.85 km/h (approx. 142.4 mph) for the MX-3 at 7,000 rpm with 4.39:1 ring & pinion and 0.80:1 fifth gear
 119,580 x 1983.60 / 1,000,000 = 237.20 km/h (approx. 148.25 mph) for the Probe GT at the same rpm with same gearing
I should also note that the MX-3's shorter wheel/tire combo will also increase the torque it puts down to the ground vs. the Probe by approximately the same amount (around 4%) due to the shorter wheel/tire combo effectively giving the MX-3 shorter gearing.
When you combine the fact that the MX-3 is hundreds of pounds lighter with the fact that it will actually put more torque to the ground than the Probe, when it comes to acceleration (assuming no traction issues and equally good launches) there will be no comparison...
- FlyVFR
93_mx3_gs wrote:fieromx3 wrote wrote:
maybe he didnt know the difference between the 2 it wasnt the smartest question byt u dont gotta be such a mean prick about it
Lol thats what he does Lol.
 LOL
 LOL
 lakersfan1 wrote:So you're wondering if a car that's about 350 lbs lighter than another, both with the same engine and tranny gearing, which would be faster? Did you have any basic physics in Jr. High science class?
 If 10 lb and 15 lb bowling balls are released from the same height at the exact same time, which will hit the ground first
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
81 Trans AM NASCAR Pace Car
80 Trans Am INDY Pace Car
www.MyMX3.com Domain For Sale!
My Feedback File
						93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
				93_mx3_gs
Both. It's gravity which carries things at roughly 120 MPH evenly. from like 50 feet or whatever. Driving force will be the same no matter the weight. Impact force however will be far different.FlyVFR wrote:93_mx3_gs wrote:fieromx3 wrote wrote:
Lol thats what he does Lol.LOL
lakersfan1 wrote:So you're wondering if a car that's about 350 lbs lighter than another, both with the same engine and tranny gearing, which would be faster? Did you have any basic physics in Jr. High science class?If 10 lb and 15 lb bowling balls are released from the same height at the exact same time, which will hit the ground first
Tatsu : Good explanation =) props.
- FlyVFR
How about the torque factor/difference to turn the diferent diameter tires?tatsu wrote:Of course, this is totally leaving aside the relative aerodynamics of both vehicles, but hopefully this helps clarify things for you!
EDIT: Oooops. I see you already posted the answer right after the first post above...Did not see it when I posteded above...
							Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
						93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- FlyVFR
Well OK then. I was just wondering how Lakers1 would answer it93_mx3_gs wrote:Both. It's gravity which carries things at roughly 120 MPH evenly. from like 50 feet or whatever. Driving force will be the same no matter the weight. Impact force however will be far different.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
						93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- Custommx3
- Site Administrator
Slammed6 wrote:Because your have the main gear ratio (1-5), then the final drive, and the diameter of the Rim/tire is the final gearing.LooseChangeRacing wrote:how would the tire size affect top speed....gear ratio's affect top speed....
The Mx3 will surpass 140. Ive rode in 2 MX-3 ZE's and hit 150. I havent tried in mine yet, I'm going to get some good suspension 1st.
 Lol.
 Lol.
