Timing belt cover
Amber
Timing belt cover
Post by Amber »
CAN SOMEONE HELO ME??? Cuz i been working on trying to get my timing belt cover off! So i got all the bults off but.........theres something holding it on still and i have no idea what! I made sure i got all the bults off. So can someone tell me what they think is still holding it on???
Amber K
93_mx3_gs
Post by 93_mx3_gs »
Magical invisible gnomes.
lakersfan1
Post by lakersfan1 »
It's meshed together in the middle, you also need to remove the dipstick sheath and the bolt in that. Need to disconnect the crank sensor. Then, you need to wiggle it apart, and then rotate at the bottom in to get it off. May be a fe more obstacles that'll make it easier if you remove them. Like the power steering resivoir hose.
mazdubber
Post by mazdubber »
It's been a while since I took it off, but for some reason I think you need to take the crank pulley off. I could be wrong though.
92 GS
'Stock'... :twisted:
kiwi_MX3
Location: Backpacking in Canada in vancouver 13march onwards
Post by kiwi_MX3 »
Can you wait till tomorrow and ill photo the front of the donk,
and yea it helps to pull the crankshaft pulley off, though you
can get the cover off with out removing it but you tend to crack it
lakersfan1
mazdubber wrote:It's been a while since I took it off, but for some reason I think you need to take the crank pulley off. I could be wrong though.
Yes. There is a bolt or two hidden underneath you can't get to without removing the crank pulley also.
Custommx3
Site Administrator
Post by Custommx3 »
The online manual should show you the proper procedure and where the locations are that hold it on/together.
