How much are water pumps?
Amber
Post by Amber »
Ok so now my water pump went out! How much do those run$$$$
Amber K
fieromx3
Post by fieromx3 »
http://oem.overnightautoparts.com/parts ... =G&dp=true
there is a link for water pumps and will give u an idea how much they r......i got a pump i can give ya for 15 bucks if u like or get a new one
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
2fazed
Post by 2fazed »
I think there around $75 at an autostore. I bought a brand new on on Ebay shipped for $35.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
Gro Harlem
Post by Gro Harlem »
they run 30-65 at most auto parts stores.
installing requires you to remove the timing belt so if it hasn't been replaced recently you should do that as well. Timing belts run 40-60.
If u pay someone to do the install expect to pay at least 200 labor and maye more like 400 b/c timing belts on these crammed V6's is a pain.
DONATE TO MX-3.COM
JYOUNYA1
Post by JYOUNYA1 »
Advanced auto part sells them for like 50-65$ with like a 1-2 year warranty.
~Jay
93 MX-3 GS 1.8 Liter V6 Teal Mods: Pace (Maker) Setter Custom Catback/ Phantom Auto Meters: Voltage/ Water temp, Air/Fuel (in which not one gauge except voltage works) / Custom piece of s*** intake / 17" RacingHart Z5000 wrap in Khumos that are dry rotten / Altezza Tail lamps/ Custom Black interior (still in the works)/reverse indiglo gauges/ Push Button Starter/ Viper alarm with Proximity sensor/ Brembo slotted and dimpled rotors/ rear hatch shade/ Pioneer Premier DEH-840MP, ,2 custome fitted 6"inch pioneer door speakers, 1 Pioneer Premier 200 watt amp
lakersfan1
Post by lakersfan1 »
JYOUNYA1 wrote:Advanced auto part sells them for like 50-65$ with like a 1-2 year warranty.
~Jay
Autozone sells them for that much with a lifetime warranty. :P
rebel2k4
Post by rebel2k4 »
I got one from autozone for $50 and its lifetime warranty.
The timing belt does not need to be removed. Ive done two water pumps without touching the timing belt.
98 Ford Ranger 3.0L
