How much are water pumps?
- fieromx3
http://oem.overnightautoparts.com/parts ... =G&dp=true
there is a link for water pumps and will give u an idea how much they r......i got a pump i can give ya for 15 bucks if u like or get a new one
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
14.4 @ 96.7
14.5 @ 97.2
they run 30-65 at most auto parts stores.
installing requires you to remove the timing belt so if it hasn't been replaced recently you should do that as well. Timing belts run 40-60.
If u pay someone to do the install expect to pay at least 200 labor and maye more like 400 b/c timing belts on these crammed V6's is a pain.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- JYOUNYA1
Advanced auto part sells them for like 50-65$ with like a 1-2 year warranty.
~Jay
~Jay
93 MX-3 GS 1.8 Liter V6 Teal Mods: Pace (Maker) Setter Custom Catback/ Phantom Auto Meters: Voltage/ Water temp, Air/Fuel (in which not one gauge except voltage works) / Custom piece of s*** intake / 17" RacingHart Z5000 wrap in Khumos that are dry rotten / Altezza Tail lamps/ Custom Black interior (still in the works)/reverse indiglo gauges/ Push Button Starter/ Viper alarm with Proximity sensor/ Brembo slotted and dimpled rotors/ rear hatch shade/ Pioneer Premier DEH-840MP, ,2 custome fitted 6"inch pioneer door speakers, 1 Pioneer Premier 200 watt amp
I got one from autozone for $50 and its lifetime warranty.
The timing belt does not need to be removed. Ive done two water pumps without touching the timing belt.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
