Clicking From Passenger Side Rear Wheel
SE MX-3
Post by SE MX-3 »
I have a clicking noise coming from my passenger side rear wheel. The click seems to rise and fall with speed. Is it the bearing that needs to be replaced? How long should this take to fix, and are any special tools needed?
Matt Domenick
1993 GS-ZE
JWMX3
Post by JWMX3 »
The rear bearings are replaced with a whole new hub assembly, while the fronts u reuse the hub and have the bearing pressed out
normally when a bearing is gone its more of a whuuuurrring noise, not clicking
what about when you go over bumps? is there any pronounced noises ?
onderground_mx3
Post by onderground_mx3 »
axle
PATDIESEL
Post by PATDIESEL »
REAR is not an axle.
I'd also check that the brake clips aren't hitting the wheel. I had that happen to me once where one broke and was flapping like a playing card in a bicycle wheel. :lol:
hgallegos915
Post by hgallegos915 »
hmm i had that problem..well have...its my rear rotors..to thin nd the brake is floating not touching the dish so it moves around..thats whats wrong in mine..im hoping urs is the same
-hec
onderground_mx3
oh s--- should have read that better didnt notice the REAR part
SE MX-3
Post by SE MX-3 »
I did just change the rear pads, so I'll take a look today and make sure the clips aren't hitting the wheel. The sound is like a squeaky click. I didn't notice anything when going over bumps, but I'll pay close attention today and let you know.
Matt Domenick
1993 GS-ZE
wazza
Post by wazza »
check your tyres, it could be that you've picked up a screw or even just a rock in the tread.
...always look for the simplest fix first
A man's got to know his limitations
