zx-2 question
Buff1110
zx-2 question
Post by Buff1110 »
the zx-2 upper perch mounts will fit on the mx-3 v6 correct? my stocks are shot and im ordering the zx-2 struts with thrust bearings anyhow so should i just order the zx-2 perches as well or must i use the mx-3 ones and drill the whole a bit larger?
Dan
02 Tacoma TRD - Daily
therealstasman
Post by therealstasman »
Last edited by therealstasman on February 17th, 2009, 1:05 pm, edited 1 time in total.
Buff1110
Post by Buff1110 »
my problem is the rubber portion that you see on the strut when you lift up your hood is all cracked and worn, so i need that as well as 4 struts
Dan
therealstasman
Last edited by therealstasman on February 17th, 2009, 1:06 pm, edited 1 time in total.
lakersfan1
Post by lakersfan1 »
I just ordered new MX-3 strut mounts from partsamerica.com
For some reason, they came up less expensive ($29.99 each) when I typed in my old zip in Nevada vs. $41.99 for Chicago, so I typed in I lived in Nevada still and they gave me that price plus free shipping. I believe the Monroe Strut-Mate Mounting Kit also comes with new strut bearings at that price. I guess I'll find out when they get here. If they include strut bearings, I find that deal hard to pass up as I've seen just the boot cost $30 some places.
lakersfan1
As a follow up to finalize my thought in this thread, yes the Monroe Strut Mate Mounting Kits come with strut bearings as well. They're a pretty good deal. I just bought a second for my other side at PepBoys locally, and that was only $32 locally.
slimmyslim1420
Post by slimmyslim1420 »
Is there anywhere else to get the zx2 tokiko strut kit other than ford directly? Also has the right up been found for instalation of them?
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
lakersfan1
If you're talking about the cheap $150 Tokiko ZX2 struts, then yes, you need to go through a Ford dealership because they're Ford Racing exclusive replacement parts.
slimmyslim1420
Are they still good quality even though they are cheap? Is that $150 for all 4 or 2 or 1?
lakersfan1
slimmyslim1420 wrote:Are they still good quality even though they are cheap? Is that $150 for all 4 or 2 or 1?
That's for all 4. If you bought regular market Tokikos (non-Ford Racing) they'd be over $100 EACH. I don't have either, so I can't comment, but the people that have them seem to like them.
therealstasman
Last edited by therealstasman on February 17th, 2009, 1:13 pm, edited 1 time in total.
rustyschopshop
Post by rustyschopshop »
here is a very important note that not very many people know about the zx2 struts. You want to get the struts and springs from the sr version of the zx2, they have a shorter strut rod and are the only ones that come with the eiback springs.
lakersfan1
therealstasman wrote:
lakersfan1 wrote:As a follow up to finalize my thought in this thread, yes the Monroe Strut Mate Mounting Kits come with strut bearings as well. They're a pretty good deal. I just bought a second for my other side at PepBoys locally, and that was only $32 locally.
Could you let me know what else comes in this kit? Strut mounts and strut bearings that go into the upper spring perches? Thanks.
Isn't that what I just said? A strut mount and a strut bearing???? :?
therealstasman
