KFZE???????????
KFZE???????????
I got a 93 4 banger mx3, im thinking about ordering the KFZE, i did a search on it, but nothing came up. I can get it for $450 with the engine,tranny,ecu,and harness, or 500 from a dif. site with the engine, exhaust manifold,ecu,harness,all the cables,brackets,sensors,distributer,alternator,intakemanifold,power steering pump,and the a/c copressor. I dont know which one would be easier. Plus how hard is it to drop into a 4 banger???Any advice or info wuold help,thanks.
where are you getting this engine !! i want one!
-hec
no offense, but you'd have to be NUTS to try an I4 to V6 swap. If you REALLY want a fast motor, get a BP motor, and turbo it. There are plenty of aftermarket parts available for it too. Miata parts can often be made to work with them, making it quite easy to find bits.
my cardomain site: http://www.cardomain.com/memberpage/793483
Well if anyone can find me a bpt, for 500 hun, then i will. I was wandering cuz one of my best friends is a certified mechanic, and the engine came with everything i wuold need. Btw the site is http://www.japandomesticmotor.com . The only thing i would need i think is that tranny, and wuold i have to chang the axles too? And yes i am talking about the kfze,not the klze.
no, you need the wiring harness, engine and tranny mounts, tranny, axles, possibly the GS steering unit (although I kinda doubt it... it's better though!
) and all sorts of other junk. Ain't worth it. Even Vaughn Nishimura says so. There's a reason why it says "NOT RECOMMENDED" when you look at the I4 to V6 conversion at the engine swap page.
- atlantamx3
While the KF-ZE may SEEM like a cheaper choice to begin with-- it will cost you more in the long run to swap everything over and source all the various parts.
Besides-- The KF-ZE is not even a good engine. For the money, if you were going to do the I4 to v6 swap-- just spend the extra $$ for a KL-ZE and get 30-40 more horsepower.
Just my opinion.
Just my opinion.
