hold flashes in D not in R
esoterikest
Post by esoterikest »
92 GS v6;
the hold flashes as soon as I put the shifter in any of the forward drive (D,L,S) slots but not in reverse and does not move past the first gear which I hardly get any power (torque?)out of anyway. Is she dying?
Started after a 250 mile trip.
jplar
Re: hold flashes in D not in R
Post by jplar »
I had something to that effect this past summer. Check your tranny fluid levels and see if it's leaking anywhere.
perhapsadingo8yerbaby
Post by perhapsadingo8yerbaby »
Double post -- appears in V6 Technical/Performance as well...
Andrew_Pakula
Post by Andrew_Pakula »
I think it just depends how your ATX is damaged. I think it just means your drive gears are screwed but your reverse is ok. When my tranny went last time drive gears worked (although not very well) and the reverse didn't work at all.
<small>[ October 10, 2004, 03:40 PM: Message edited by: Andrew_Pakula ]</small>
Return to “Transmissions”
