wed at the track was bad
A forum for Drag Strip/Track Racing Discussions. (NO Street Racing or Kill Stories, they WILL be deleted.)
aaronthehic
Post by aaronthehic »
the slicks are to tall, my n2o was low my best 60ft was a 2.049<p>hit the n2o in fist and the slick broke out hit the rev limiter , flames shot out of the hood and 3' out the tail pipe. I thought I blew the motor , instead the flex pipe on the intake blew out cause of a manifold backfire. :eek: <p>can't get the slicks hot enough on burnout it just drags the car around. so I may stay with the drag radials for now and work on a bigger shot combo :shrug: maybe later use shorter slick and try it again.
13.023 @ 105 mph
torpedan
Re: wed at the track was bad
Post by torpedan »
Eeek bad night.. i bet the crowd loved to see the flames though.<p>tough luck man..
-torp.
I don't own a Mazda.
maldo
Post by maldo »
You are lucky that you are ok. One of the Miata guys did a dyno run with JRS and a 75 shot, completely blew the manifold into pieces. The guy operating the dyno had to get rushed to the hospital due to lacerations. There was pretty much nothing left above the block all due to a n2o backfire.
torpedan
Post by torpedan »
ugh dont say things like that otheriwse i will flintch every time someone hits the gas...
-torp.
lazzyie
Post by lazzyie »
wow, be careful man!!!
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi :)
aaronthehic
it was a big back fire. I thought at first that one of the heads had blown off, a big bang , flash and flame from under the hood . <p>I would have been entertained to watch me run too bad I was too busy trying to get some kind of a run in.<p>has anyone run slicks? do they grab well but break out bad ? I was spinning in second and that should't happen.<p>the slick was a 26.5 X 8.5 X 14<p>my best time was<p>rt .616<p>60ft 2.123<p>330 5.901<p>1/8 8.880 @ 83.2<p>1000 11.463<p>1/4 13.672 @ 101.58<p>anyway next wed I'll try again , weather permitting
13.023 @ 105 mph
torpedan
Post by torpedan »
That doesnt sound to great for slicks.. yeah i doubt you got them hot enough.. Be sure you have someone spray a good sum of water into the pit so you can do a good burnout.
-torp.
Gkreator
Post by Gkreator »
HAHAHAHA!!! At 1st I thought this topic read "WEED at the track was bad"!!! :D :shrug:
Dave Hyatt
94 Teal MX-3 RS 5 Speed
http://www.cardomain.com/id/gkreator_inside (New Pics!)
Custommx3
Site Administrator
Post by Custommx3 »
it is.. bad reaction times ;)
Gkreator
Post by Gkreator »
LOL!
Dave Hyatt
aaronthehic
that green light is like talk'n to me man :cool:
13.023 @ 105 mph
Return to “Drag Strip/Track Racing”
