does all 2.5L will fit exactly with the mounts of 1.8?
				khas
Does all 2.5 fit exactly with my stock 1.8 mounts or is there any engines codes ..or years that will fit better .Thx
						- Custommx3
- Site Administrator
Re: does all 2.5L will fit exactly with the mounts of 1.8?
I believe 1 or 2 motor mounts have to be moved, but you can use your stock mounts.
				khas
all the holes(2) are made .only have to bolt it at the other place, with no other modification.thx for replies
i havent read anything on moving mounts...Which mounts do you move?<p>[ May 09, 2003: Message edited by: Nd4SpdSe ]</p>
Yea which ones do you move?  I need to know that too? also  will the 4 cyl body engnie mounts  work with the 6cyl engine?
							www.krazykustomz.com 1994 Blaze Red V6 2.5 in the works, 1995 eclipse gsx (winter beater haha)
						- Buff1110
i just installed mazdaspeed mounts with my klze with ms8 manifold and everything lined up perfectly. no relocating or drilling additional holes. i used k8 mounts.
							Dan
02 Tacoma TRD - Daily
