Eunos Presso won't Start
Eunos 30X/Presso/Autozam AZ-3 Discussions
Davies
Post by Davies »
Hi all,<BR>I am in a desperate situation. My mechanic can't get my Eunos Presso 1844cc to start after he had re-fitted the water pump. He said that car started yesterday and stopped. He has not been able to restart it again. He said the distributor, fuses,fuel pump are working fine. <P>He wants to know exactly how to set the timing on a Eunos Presso as he thinks that the problem is with the timing. (Note that I recently changed a new timing belt).<P>Any help would greatly appreciated.<P>Davies
jaydog5678
Re: Eunos Presso won't Start
Post by jaydog5678 »
Timing belt is off, or broken. 1 of the 2 for sure. I'd double check ignition timing too. ;)
Return to “Eunos 30X/Presso/Autozam AZ-3”
