Mykil
Cosworth rs escort a Mazda??
The escort is really a mazda right?? b/c i just found out about these beasts
, and really want one but i want to stay true mazda/imports. Thanx in advance.
Mykil
Mykil
- Custommx3
- Site Administrator
Re: Cosworth rs escort a Mazda??
Its a cosworth 2.0L engine..
Not a mazda product
Not a mazda product
JeffsCosworth
it s a 2,0 L Zetec engine (cosworth (ford)).... you can put it in your MX3 as well.. contact me for more info !
- Custommx3
Im sure its not a simple swap.
I didnt know Ford owned Cosworth...
- papa roached
why not just share the info with everyone?
hey Barry, last i knew ford owened em, and Sterling as well. the Ford Dealership/Garage my grandfather worked at, had Cosworths, Sterlings, and Fords in the semi area... now that i think of it.. what is a semi company doing making escorts???? maybe i jus messed this up
*note i will not be doing the rx7 hatch conversion, id rather get a BP*
