Rotary engine info
Other - General Mazda Discussions
Brainless
Rotary engine info
Post by Brainless »
I would like to learn more about rotary engines but I don't know where to look. Is there any book or detailed web site I could look at?
Jonathan Michaud
93 Red RS
Gro Harlem
Re: Rotary engine info
Post by Gro Harlem »
DONATE TO MX-3.COM
guyaverage
Post by guyaverage »
Try www.rotaryengineillustrated.com , or also try www.monito.com If you really wanted to get into it, go to Ebay and do a search on "wankel" or "rotary engine" and there are usually 5-10 "visible engine" 1/4 or 1/5 scale model kits fairly cheap, putting one together will pretty much show you all there is.. there isnt a lot to them, 2 rotors and an eccentric shaft and a bunch of expensive seals. They can run practically forever if treated right, but if you dont maintain them religiously or if you let it overheat even just once they can be fragile as glass.<p>[ July 23, 2003: Message edited by: guyaverage ]</p>
"The answer is: More power. I dont care what the question is."
-Tim Allen
Return to “General Mazda”
