Trouble removing break drum
Tron
Post by Tron »
Can anyone tell me a good way to loosen the screws holding the break drums on? I've tried liqid wrench, a number 2 screwdriver with channellocks while tapping with a hammer. Thanks....
Green 94 MX3 5 Speed 1.6 DOHC PRM CAI
BPTurbo
Re: Trouble removing break drum
Post by BPTurbo »
sometimes you have to use pneumaic screwdriver.
92RedMX3
Post by 92RedMX3 »
Personally i used a socket wrench(1/2") with a socket that would hold a #2 phillips bit) It got them off and never had a problem since.
Tron
Post by Tron »
Thanks for your input guys. I'll give these ideas a try. ;)
Tron
Post by Tron »
Mission accomplished. I had to change my left rear wheel bearing. I got the screws in the drum off using a phillips apex and ratchet with a 3/8" socket. The drum was stuck to the hub so I screwed a bolt (#10 I think) in the threaded hole of the drum to get it free from the hub. Used a flathead screwdriver to get the dust cover off the hub. Then I used a 3/8" centerpunch to decrimp the hub retaining nut followed by a 32mm socket to get the retaining nut off the axel. Greased the new hub assy, and installed it on the axel and put everything back together. Works great, no more noise. Don't remeber my car being so quiet. Anyway, someone my find this info usful so hope it helps.
MX_Sid
Post by MX_Sid »
Woah! Tron! your awesome! great post, I was trying to figure what I would need to get together and your precision .... nice! Much Appreciated.
I HATE mechanic shops and LOVE junkyards!!
Evo_Spec
Post by Evo_Spec »
for future reference, i use the hammer method (without needing the impact screwdriver)
http://www.youtube.com/watch?v=YxQk7Pz_vfc
MX_Sid
Post by MX_Sid »
that was a pretty neat video :D one of my screws is stripping on one side so i was thinking about taking to a shop and having them replace the screws hehehe that way all i gotta deal with is easy new screws hahaha. I don't really look forward to drilling out a totally messed up screw, sounds like a bad day :crying: Then again, maybe i should find an impact driver! do they have 'em at Harbour Freight? Thanks for the info!
