alternator problem
alternator problem
when my lights and radio are on and i hit my brakes the radio cuts out and my speedometer drops to zero,but after running for a while it stops and drives just fine.is ther anything else it could be othe than the alt.
Re: alternator problem
Your battery should make up for it, so your bat may be out
Sonicxtacy02
i had this problem recently and fixed it just by resetting the ecu. its like the car almost dies after hitting the brakes. Reset your ecu and see if that helps
Shaun Newman
Hey! That is a problem I am having. The brake thing. How do you reset? Unplug batt?
white94mx3
Yeah, unplug the battery and leave it unplugged for about 1-2 hours, and everything should be fine.
1994 Mazda MX-3 RS (Project RS-T)
- Custommx3
- Site Administrator
unplug the battery, depress trhe brake to let the taillights drain the power, wait 30 seconds, then plug it back up. 1-2hrs is a little too long.
thanks it seems to be working .I drove it all day and no problems at all.Thanks
