I guess I haven't updated this thing in a while.
These are probably going to be out of order. But here's a bunch of pics with some upgrade listing below. (And probably already seen them if you're on facebook)
This is right after I lowered it, next to a beast. The springs hadn't settled yet.
Chalkboard paint never grows old.
Sitting low, with a GS lip. I like this picture a lot.
Who needs a truck? (returning a core trans for my dad)
After failed hood struts, I went topless for a while.
Josh gave me the hood off his AWD MX-3
How the car sits right now...
Parts install pics
Rear KYB GR2s with B&G springs
Front KYB GR2s with B&G springs
Energy Suspension bushings all the way around (Front LCAs, rear trailing arms, rear lateral links)
Brand new Whiteline rear swaybar Solid 22mm
Ford ZX2 tubular trailing arms
More bushings, Moog strut bellows/bumpstops, Moog strut tophats, Moog inner/outer tie rod ends, Moog ball joints, Moog spring seats
Complete GS rear subframe. I'm waiting on new pads and rotors. I'm currently installing the Energy Suspension TTL bushings and swapping over the Whiteline sway bar.
String line alignment after I installed the wider RX7 ball joints to alleviate some axle issues
Parts that I've installed
Okay, I hope I remember it all
I went through the entire suspension and underside of the car.
B&G springs
KYB GR2 struts
Moog:
Strut tophats K8995
Bellows K90464
Bump Stops (same part # above)
RX7 Ball joints K9427 (Stock Moog MX-3 Balljoints part #K9967)
Spring seats K8995
Swaybar endlinks (front and rear)
Energy Suspension bushings:
ZX2 trailing arm bushings 4.7123G
LCA bushings (Need ZX2 rear carrier) 4.3152G
TTL bushings 9.9108G
94+ knuckles (to fit the RX7 ball joints)
GS rear subframe
Slotted rear rotors
Ceramic brake pads (front/rear)
Whiteline 22mm swaybar (bushings too)
GS Rear lower tie bar
OBX Upper rear strut tie bar
Ebay Upper front strut tie bar
Inner and outer tie rod ends
Still rocking a NA BP05, with an F5M-R tranmission.
I think I need to work on the engine now...
And my GS, waiting for a new crank...
