To start, glamour shots of "Angel" my MX-3...
Currently my daily driver is sitting in my driveway without an engine. I blew a headgasket and figured it'd be a good time to do a BP swap.
So I bought a 92 Protege LX after tonnes of hassle from the girl who owned it. When i finally get to see it the body is beat and battered to s#it. Under the hood is a 1990 BP with unknown miles on it. But a quick look under the valve cover and I could tell that it was in good condition. Offered the girl $300 for it and towed it home. The car had a bad tranny, but who cares? It was an automatic. Looking at the car a little closer when I got it home I really could tell that the car had been taken care of *before* the previous owner.
So I started the tear down on the Protege. Cut 90% of the wires, hoses, cables and ALL of the A/C crap. The AC didn't work anyway, and there was no coolant.
Everything came off pretty easy since it had been recently installed (within the past 2 years). The CV axles on it were like new and didn't want to come out. I tore one trying to get it out, and cut the other for good measure.
My MX-3 I took my time and carefully marked and disconnected everything.
Right now I'm at the point where I have both engines out and the tranny off the B6. I cleaned up the tranny a bit, a quick wipedown of the engine bay. Tomorrow I will clean the BP engine and strip the tranny off of it, swap the flywheels, mount the new clutch & tranny, and then start on pulling the ECU. Kill the AC, swap the mounts and maybe a paintjob to the valvecover.
*Edit* 9/29/09 --
Clean the BP *done*
Flush waterpump/system *done*
Take off the tranny *done*
Kill the A/C *done*
Cut that stubborn bolt off the exhaust header *done*
Find wiring diagram for auto BP
Find wiring diagram for manual B6
Run VICS wires
Rewire B6 wires to fit BP ECU
Screw that rewiring crap .. PM sent to Ryan for BP09 ECU
----Decided just to go buy the right ECU since I'm not sure if the rewire would work ----
Rebuild clutch slave cylinder *done*
Shave flywheel --decided against it for now... need car soon
Mount clutch/tranny *done*
Swap motor mounts *done*
Rebuild CV Axles *done*
Replace CV shaft seals *done*
Mount motor in body *done*
Having issues getting the CV shafts to mate back into tranny ... *done*
Gonna finish the mechanical connections *done*
Start electrical wiring on *done*
Vacuum hoses *done*
Oil/Water/everything else *done*
Found a local ECU for less ... Now to pick it up (still running the B6 ECU)
So as of 6:30 pm 09/30, the car is running on a B6 ECU, no VICS yet, and a small exhaust leak at the exhaust mani.
Tomorrow I take her out to really test her.
Next projects -
-- BP09 ECU
-- Fix exhaust leak
-- Wire VICS
-- Change Clutch Master Cylinder
-- Bleed hydraulic system
-- Locate mirror ...
-- sand/bondo/bodywork/paint
Bought all the tune up stuff. No local ECU as far as I can find. Also a new passenger mirror (blaze red) because a support beam fell and destroyed mine. Have to start thinking about the dents and bondo after this. If I paint it, I'm just going to keep it blaze red.
Now for some pictures
My engine bay all wiped out and tagged for reinstall.
BP engine right after I got it out.
BP backside *blush*
B6 waiting to be dropped back in the Protege before sending it to the scrapyard.
Also if anyone knows where I can find the wiring I need to do after all this (VICS and such) please point me that way.
