Bp or K8??
Re: Bp or K8??
Post by Josh »
DeadMaker wrote:So in a few words there is no reason to change my cluster while i will be using bp with g series trans.
Thanks..
Yes, just make yourself a 1/2" spacer and you are good to go.
RobMinhas
Re: Bp or K8??
Post by RobMinhas »
Hey Josh, you don't have(or had) any intermittent signal problems with the adjustment you made? Also was there any chance of it falling in?
A local member on the forum did a similar mod and it fell in, and then another similliar mod and the signal for the speedo was intermittent, that's why I ask.
I need to try this, I haven't seen a 92-93 RS in ages...
Re: Bp or K8??
Post by Josh »
Nope, I never had an issue. I ran it for nearly 3+ years like that. I will find my extra one I have somewhere I am confident I kept one.
DeadMaker
Re: Bp or K8??
Post by DeadMaker »
The only problem is that there is no key to turn on the donor car to see in which situation the engine is.
So any tips on where to look or what to inspect?I know if the head gasket is blown there must be oil in the coolant but this is not enough..
Black Mazda Mx3 Rs 1997 B6DE
RobMinhas
Re: Bp or K8??
Post by RobMinhas »
Do you have a compression tester?
Also I think it's supposed to be fairly easy to "Hotwire" our cars so maybe someone can PM you that info, it's not like you need the donor cars interior harness.
If possible try to pop off the valve cover and timing cover to look for irregularities suck as excessive scoring on the camshafts or lots of oil behind the cam gears.
Shift through all gears as well.
With a no starter you have to assume everything and anything needs replacing so it's hard to say exactly what to look for.
DeadMaker
Re: Bp or K8??
Post by DeadMaker »
Yes i have a compression tester.
Thanks Robminhas
Anyone knows how to Hotwire a mazda 323 bp 92 model?
Surgeonasst222
Re: Bp or K8??
Post by Surgeonasst222 »
DeadMaker wrote:Yes i have a compression tester.
Thanks Robminhas
Haha I know your serious and I know why you want to it is just funny to read :lol:
Mazda3 2012 - my NEW DD :mrgreen:
Mazda MX-3 RS 1992 - my project
Ford Focus SE 2010 - sold
Ford Focus SE 2003 - sold
Mazda MX-3 RS 1994 - sold :(
