Cleaning engine at dissasembly
easts1d3
Post by easts1d3 »
Hey guys,
What is the BEST way to clean your block and components??
Ive heard of hot tanking, degreasing, even glass beading...
I'm not too keen on the glass beading because there is no way of being sure that there isnt any in the oil galleries and coolant passages.
Hot tanking ive heard cannot be done on aluminum because it is a caustic process and will eat away at the aluminum.
And degreasing takes way too damn long lol
MrMazda92
Re: Cleaning engine at dissasembly
Post by MrMazda92 »
Degreaser is my favored method, soaking it in a 4:1 mix for 48 hours will get you a CLEEEEAAAANNN head.
It'll probably take less time, but it's easy to remember 2 days. :lol:
You'll want to scrape gasket mating surfaces first(please, use a flat bladed gasket scraper)
There are a variety of 'hot tank' cleaning solutions. Ultrasonics is good as well if you can find a place that does that. Some people use brake cleaner, I find Gunk engine degreaser works well and washes off with water.
easts1d3
Post by easts1d3 »
I dont mind spending the money to get it done professionally, I just want %100 insurance that i dont have any contaminants in the block..
MrMazda92
Post by MrMazda92 »
You could steam clean it, but I haven't seen anybody do that with a disassembled engine.
I can personally attest to the effectiveness of soaking engine parts in degreaser though.
Post by wytbishop »
Any engine shop with a hot tank will have the ability to do aluminum and your engine will be as clean as it can be. Period.
sinix3
Post by sinix3 »
when i did my rebuild i just used the gunk engine cleaner and a wire brush then hot water pressure wiashed it and after i honed the cylinders i used tide laundry detergant of all things to make sure i got every thing clean as a wistle
92 mx3 gs klze swap.
"nitrous is like a hot chick with an std you know you want to hit it but your afraid of the consequences"
RX8SE3P
Post by RX8SE3P »
wytbishop wrote:Any engine shop with a hot tank will have the ability to do aluminum and your engine will be as clean as it can be. Period.
^ This.
You will not recognise it afterwards!
1995 Eunos 30x KLZE
