Battery question
- kulluminati777
Battery question
I got a optima battery for free the part number is 8002-002 and the model number is 34. I looked on the website and its not the right one for the car but it was FREE. Can i use it? The battery is about 5lbs heavier and its made for water pumps that have a smaller engine than ours. On the site the numbers didnt seem too different but im not gonna lie i didnt understand what the hell i was looking at anyway lol
- kulluminati777
Re: Battery question
ill just throw it in......will i fry anything??
- mitmaks
Its 12 volt battery? Should be just fine
crazycanadian
You wont fry anything using a different 12v battery... The differences between the batteries relate to their dimensions (how tall/length width)... Top post/side post and what side the positive and negative are on... Also reserve capacity and cold cranking amps...
If its a 12v battery, it fits/clears the hood(really be careful with that) your terminals hook up then its should work fine...
- fowljesse
If it starts the car, you're good. What are the cold cranking amps on it? If it cranks slow, it could wear out prematurely, which isn't so bad if it was free.
Optimas usually sit lower than regular batteries, that's why the top cover actually works as a stand underneath it
Ironicly, I went to put a Redtop 34 into the Rx8 yesterday, but it sat too long and doesn't hold enough CCA to start the car.
WHere the red top came from? My Mx-3! Was one of the replacements I replaced once the Mx-3 got off the road since I had worn mine down over the years from car shows. Ran dual redtops too. The one unused replacement was sold in the part out , the other, ran in my buddy's K20 EG for a bit, than pretty much just sat unsold in my grandmothers garage with a small solar panel on it. Guess it wasn't enough. 5 year warranty, so should be good for a replacement still.
One of my yellow tops in the Xterra was actually in the Mx-3 for a bit. I bought 2 yellows to replace the reds while the red were way getting warrantied. One of the other yellows were sold as well in the part out
- kulluminati777
SWEET yeah i read its 12 volts here is a tad bit more info on it and as far as clearing the hood im actually putting it in the trunk for my battery relocation project
Battery Model: 34
Part Number: 8002-002
NSN: 6140 01 457 5296
UPC Code: 8 11405 00002 7
Performance Data
Cold Cranking Amps: 800
Cranking Amps: 1000
Nominal Voltage: 12 volts
Open Circuit Voltage (fully charged): 12.8 volts
Internal Resistance (fully charged): 0.0030 ohms
Capacity: 50 Ah (C/20)
Reserve Capacity: BCI: 100 minutes (25 amp discharge, 80°F (26.7°C), to 10.5 volts cut-off)
Physical Characteristics
Plate Design:
High purity lead-tin alloy. Wound cell configuration utilizing proprietary
SPIRALCELL TECHNOLOGY®.
Electrolyte:
Sulfuric acid, H2SO4
Case: Polypropylene
Case Color: Dark Gray
Cover Color: “OPTIMA“ Red
Group Size: BC I: 34
Post Type: SAE Post
Weight: 37.9 lb
Length: 10.06 in
Width: 6.88 in
Height: 7.88 in
Power
CCA (BCI 0°F): 800 amps
MCA (BCI 32°F): 1000 amps
Recommended Charging
The following charging methods are recommended to ensure a long battery life:
(Always use a voltage regulated charger with voltage limits set as described below.)
Model: 34 and 34R
These batteries are designed for engine starting applications. They are not recommended or warranted for use in deep cycle applications.
Recommended Charging Information
Alternator: 13.3 to 15.0 volts; no amperage limit
Battery Charger: 13.8 to 15.0 volts; 10 amps maximum; 6-12 hours approximate
Float Charge: 13.2 to 13.8 volts; 1 amp maximum current (indefinite time at lower voltages)
Rapid Recharge (Constant voltage charger): Maximum voltage 15.6 volts. No current limit as long as battery temperature remains below 125°F (51.7°C). Charge until current drops below 1 amp. All limits must be strictly adhered to.
