AZ3 B6T engine swap
- ginja117
AZ3 B6T engine swap
Hi guys i was just wondering whether it was possible to do an engine swap from a B5 DOHC to a B6T, i have an AZ3 at the moment but im wanting to get an engine with a turbo put in or in someway turbocharge this body and this B6T seems like it could possibly work????? If you guys could give me some info that would be great.
Re: AZ3 B6T engine swap
search.php?st=0&sk=t&sd=d&sr=posts&keywords=b6t
viewtopic.php?f=19&t=67587&hilit=b6t
viewtopic.php?f=3&t=74209&hilit=b6t
viewtopic.php?f=19&t=73700&hilit=b6t
- ginja117
Does anyone know whether i would be able to turbocharge this engine? it is apparently exactly the same as the B6 and B6T just with a shorter stroke is this correct??? if it is would a 323 mani with a turbo fit this engine???
Not shorter stoke, otherwise it would make it a smaller engine. Basically the same, but forged internals and lower compression. It's a possible project, the hard part is usually sourcing the B6T turbo parts. Look into cjthor, he turbo'd his with good success
- RS_OBD'oh_2
any engine can be boosted. The hardware is the easy part. The b5 is said to be a boost friendly engine. What year is it? Is It OBDI OR II? That might be your main issue.
Can it be done? Yes. But what do you expect to get out of your car?
s---, didn't see the part about him having a B5, oops
- ginja117
im not looking for huge gains i just want to have a little extra punch when i want it, ive already put in a CAI and a better exhaust system i just thought a turbo would give me that little bit of extra power im after, its a 1991 if that helps???
- RS_OBD'oh_2
I can't help with your wiring as I have no idea what/if any differences there are. AFAIK, they should be very close if not the same. Go online and do a parts number comparison with a b6 and b5 exhaust gasket. If they are the same, that's half the battle. Now you only need a bunch of $ and a fair ammount of down time to get it all done.
- Surgefilter
Yeah, the B6T manifold will fit onto a B5.
Where are you located? UK?
Let water find it's own level
- ginja117
i am located in New Zealand
- ginja117
Ok so ive found somebody that knows a little bit about turbos and he is going to install one for me
. we are going to use a Mazda GTX 1.8 DOHC manifold and turbo because according to him it bolts straight on, i will post again when it is installed and we have tuned it, looking forward to the result as i havnt seen this done on a b5 before
- RS_OBD'oh_2
please keep in mind that you may need new injectors, boost control, engine management, clutch, fuel pump and a wideband AFR guage. Just because a turbo can be bolted on, doesn't mean that is all you have to do.
Sorry if that seems like I'm talking down to you, but I have no idea what your background is.
- ginja117
na dude i understand those things, and i appreciate critical feedback , the only way to learn i think haha. but ive taken that into account and were gonna do a whole lot of work. just wanted to say that it looks like its gonna be a project that will go somewhere
- RS_OBD'oh_2
Good to read man.
Here is my log.
http://www.mx-3.com/phpBB3/viewtopic.php?f=46&t=69074
There may be part numbers that you'll need (such as oil fittings and what not)
Best of luck and enjoy the boost.
Here is my log.
- ginja117
so these parts will fit in my b5 as well???
