Constant 12V+	Blue/Red
Switched 12V+ 	Blue/White
Ground 	        n/a
Illumination   	Red/Black
Dimmer 	        n/a
Antenna 	        Driver's Pillar
Front Speakers 	5 1/4" Doors
Left Front (+) 	Blue
Left Front (-) 	Blue/White
Right Front (+) 	Blue/Red
Right Front (-) 	Blue/Yellow
Rear Speakers 	5 1/4" Shock Tower
Left Rear (+) 	Blue/White
Left Rear (-) 	Blue/Green
Right Rear (+) 	Blue/Red
Right Rear (-) 	Blue/Green
							94' Stereo wiring Diagram(with colors)
- Ryan
Re: 94' Stereo wiring Diagram(with colors)
bulls---! someone delete this post, those colours are WRONG.
Totally impossible.
Totally impossible.
- cWs306
they were the same as my car? i dont understand how there wrong?.. every wire was the same when i put my new deck in? :S .. sorry to anyone who this caused a problem too lol. was useful for me, thats why i posted..
						- Ryan
If you hooked up switched 12v to your speaker, you'll pop a fuse and pop the speaker pronto.
Another impossibility. Do you have a basic understanding of electricity? How do you not see how its wrong?
I have no idea how you hooked yours up, its not that the chart doesn't just have the wrong order of wires, it doesn't have the proper colors at all. I know for sure there are yellow and violet in the harness.
All of those are red, blue, white, green, black. No chance in hell that controls signals for everything... dimmer is orange. ground is black, not N/A. remote is solid blue, not a speaker wire. switched power will be white/red, constant will be solid red. speakers will have 8 different codes, they do not share negative channels or positive channels.
its just so totally WRONG. I'm having problems here, please delete your post.
Just get an adapter harness: so much cleaner and easier to work on when actually doing the wiring, you don't hack up your harness, easy to change radios in the future. The only reason otherwise would be to save a measly $20?
- Evo_Spec
i didn't have that choice with my car.
the previous owner mutilated it so bad i had to make a new wiring harness, at least i got to upgrade the wire size =/
True that. Mind you, could always go the wreckers and get the harness from a scraped Mx-3 to fix it.Evo_Spec wrote:i didn't have that choice with my car.
- Evo_Spec
you know, i never thought about that.Nd4SpdSe wrote:True that. Mind you, could always go the wreckers and get the harness from a scraped Mx-3 to fix it.Evo_Spec wrote:i didn't have that choice with my car.
i already has some cheap 16ga monster wire sitting around so i just wired it all through, and one of my wires didn't work either so that's probably why i didn't consider a junkyard harness
