Hi Folks,
I may have access to a spare 1.5 DOHC engine out of the Japanese version of the MX3, the AZ-3. I believe the engine code is B5-ZE, it is supposed to be rated at around 120hp stock.
I am considering building this engine to run a lot of boost, my question is will the forged rods and forged pistons and ACL race bearings that are available for the Miata 1.6 DOHC work in this engine?
Please advise.
Engine Question 1.5 DOHC
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
- Ryan
Re: Engine Question 1.5 DOHC
boosting a small displacement will yield less power for the same amount of boost....
And I'm pretty sure the bores are the same at 78mm. stroke is not, and therefore rods won't interchange.
no idea about crank journal dimensions.
I just wouldn't boost a b5. choose bp, if possible. no replacement for displacement.
