I've always wondered this. Would sand blasting and powdercoating/painting the intake manifold affect the flow of air through the manifold or change the natural resonating frequency of the manifold thereby throwing off the VRIS points a little? And for VCs, do you guys powdercoat just the exterior portion or the inside of it as well?
I have a feeling the more technical guys like wytbishop will jump on this one
Remember its the whole motor vibrating. The I/M is a fairly rigid structure as well. Its not like shaking different consistency jello, its like shaking a brick versus shaking a painted brick.
The common arguement is that it holds heat in, and warms the air, which we all know is bad...
2003 Forester Xti - EJ20K swapped. Feedback
The resonance doesn't affect the VRIS, that's the air flow path. The resonance system is mostly do to with the sound of the motor. If you've put on a CAI, you've already changed it massively, so I wouldn't worry about it.
Indeed, Ryan is right, it'll ask as an insulator, but many have painted/powdercoated IM's, so it depends on how serious you are towards performance.
1992 Mazda Mx-3 GSR - 2.5L KLZE : Award Winning Show Car & Race Car ['02-'09] (Retired) 2004 Mazda RX-8 GT - Renesis Wankel : LS3 Coils, BHR Mid-Pipe + Falken RT-615K 245/40r18 2011 Mazda Mazda2 GS - 1.5L Manual : Yozora Edition (1 of 500) 2003 Nissan Xterra SE - 4x4 Supercharged : 2" Body Lift, 4" Suspension Lift & 33" MTR Kevlar 2001 Nissan Frontier SE - The Frontrailer : Expedition/Off-Road Trailer Project
