sunroof leak, need help
Other - General Mazda Discussions
Ukrman
Post by Ukrman »
My sunroof started leaking recently, i think the rubber seal just doesn't hold the water anymore. Does anyone know where I can buy one, semi cheap. From the dealer its $140, so if anyone knows where i get one cheaper, or at least know the part number, please let me know
thanks
-Bo
92 Mazda MX3 GS
http://www.cardomain.com/id/ukrman" onclick="window.open(this.href);return false; - cardomain page
viewtopic.php?f=46&t=66481 - worklog
viewtopic.php?f=37&t=72099 - feedback
viewtopic.php?f=2&t=71757 - stuff for sale
http://s2.metaldamage.com/c.php?uid=159229" onclick="window.open(this.href);return false; - biggest waste of time
umcamara
Re: sunroof leak, need help
Post by umcamara »
Ukrman wrote:My sunroof started leaking recently, i think the rubber seal just doesn't hold the water anymore. Does anyone know where I can buy one, semi cheap. From the dealer its $140, so if anyone knows where i get one cheaper, or at least know the part number, please let me know
thanks
-Bo
To 11-1-91.............................FB03-69-895C
From 11-1-91..........................EA05-69-825
'96 Silver Stone Metallic MTX RS
'98 BMW 328is M-Tech
Feedback Thread
Dali
Post by Dali »
its probably not the seal on the sunroof, it will be the drain tubes that run down the a and b pillars. usually the front tubes get plugged with junk and it backs the water up into the frame which then leaks into the car. the tubes come out behind the front fenders, it will be about 3" of tube sticking out from the body. stick a air hose in the top of the tubes in each coner and blow them out, might make a mess and blow back some goo. give it a shot.
1993 White gs klze.
Ukrman
Post by Ukrman »
thanks
92 Mazda MX3 GS
umcamara
Post by umcamara »
Dali wrote:its probably not the seal on the sunroof, it will be the drain tubes that run down the a and b pillars. usually the front tubes get plugged with junk and it backs the water up into the frame which then leaks into the car. the tubes come out behind the front fenders, it will be about 3" of tube sticking out from the body. stick a air hose in the top of the tubes in each coner and blow them out, might make a mess and blow back some goo. give it a shot.
This is true. When I first got my car, I was literally having buckets of water dumped on me through my headliner. Somebody had installed an aftermarket sunroof at some point in time and hadn't bothered to run the 4 drain hoses, so the water just collected in the plastic well that runs around the sunroof underneath, and then spilled over. Running those hoses was not a fun job.
Only thing is though, that water shouldn't really be getting into that well unless there's a leak in the seal, or the sunroof is open. The drain hoses really are only there as a last line of defense.
The switch for my sunroof was fried because of the water leaking in, so it turned out that my sunroof wasn't actually closed all the way.
I would tend to think that you could have a leak, but the hoses being plugged is also another possibility.
Feedback Thread
MX3-Life
Post by MX3-Life »
Any part you decide to change with the sunroof just go down to your local Junk Yard and take it off a MX3 Sunroof. No need to pay for a brand new one unless you really want to...
Ukrman
Post by Ukrman »
i cant seem to find these tubes to clean them out :?
92 Mazda MX3 GS
mudvaynedg
Post by mudvaynedg »
Im having a leaking problem also but its nowhere to be found from inside the car its like it is just appearing out of nowhere so I guess its under the carpet or something...
The spot where the water collects is the floor board behind the driver seat its raining here and I just went out to see if it was leaking well their is water in the floor board but no signs from touching and looking where it might be coming fromm
could cleaning out the tubes help my problem either way I still want to clean them out just need to know where they are..... Thanks
Ukrman
Post by Ukrman »
:?: still no luck of finding the drain tubes to clean them out :(
is it from the inside or the outside?
92 Mazda MX3 GS
tysoe
Finding the front drain tubes
Post by tysoe »
I had this problem, my MX-3 started leaking onto the passenger seat and into the footwell. I have a cracked windscreen and the cowel rubber seal at the bottom of the windshield is loose, I thought that was the problem and since the car has been off the road for a while I used a cover.
This year I removed the cover and forgot about the leak. Anyway found about 1" of water in the footwell and it was actually the roof liner that was soaking wet. Came to this site again and found out about the drain.
SOLUTION
I don't have any fancy tools, pulled off the inside A pillar covers and found the black drain tube,
flushed out the inside of the front wing with the hose from the front of the door opening. After all the dead leaves and crap were removed I saw the bottom end of the drain tube.
I filled the area around the drain in the sunroof opening with water and squeezed the tube hard to push some of the gunk out the top and removed debris that was released with a scredriver and rag.
To get to the lower end of the train tube you have to go to the wheel well, and remove 2 plastic clips 1 metal/plastic clip and a metal screw and washer so the wheel well lining can be pulled back. I now have easier access to the lower tube.
I don't have any fancy tools, there just happened to be some long thin vine roots that had spread under the car, I pushed this up the tube till the blockage broke and water came gushing out. (you can probably use a thin piece of electrical wire to do the same thing.
Poured water in the top, water gushed out the wheel well, So all is good. Put it all back together in reverse order to how you dismantled it.
A bit lengthy, but I hope that helps anyone that comes by with the same problem.
Wow tysoe joined in 2001 and only 47 posts and a sunroof leak makes it 48. Man talk about lurking, this brings lurking to a whole new level. :P That's like only 5 posts a year. Oh ya my sunroof leaks but only from the passengers side so I need to clean my tubes too.
Dark_Rider2k3
Post by Dark_Rider2k3 »
Would this be under body in the online manuals for the sunroof drain tubes?
kulluminati777
Post by kulluminati777 »
my sunroof doesnt leak anymore i know for a fact but i was replacing my carpet and in the front passenger side it was pretty wet in the front towards the left..any ideas
Re: Finding the front drain tubes
tysoe wrote:I had this problem, my MX-3 started leaking onto the passenger seat and into the footwell. I have a cracked windscreen and the cowel rubber seal at the bottom of the windshield is loose, I thought that was the problem and since the car has been off the road for a while I used a cover.
SOLUTION
So many people have this problem this should almost be in the FAQ. Great write up tysoe
kulluminati777
i think its coolant and oil thats leaking in not water
Return to “General Mazda”
